drum fans
  • drum fans
    i am looking to buy a 36"-48" drum fan in the $2-300 price range it will be used less then 30 hours a week, any sujestions?
    9/11/01, never forget.
    Re: drum fans
    wish i could help you, but i'm a sectional fan
      Re: drum fans
      hummmmmmmm
        Re: drum fans
        try hare
        Industrial Grade Drum Fans Super Air Movers - Commercial Grade Fans/Air Movers
          Re: drum fans
          one of my clients, a seaplane srvice, uses the Air King direct drives in the hangers and they DO move some air and run about 16+ hours a day
          steve
            Re: drum fans
            OSC
            Is this the type of fan you have in mind? If yes, you may want to check a farm supply place like TSC - Tractor Supply Co.
            www.tractorsupply.com (Home Pace where you can try to locate one of their walk-in stores)
            Northern Tool & Equipment has them and I'm sure could ship one to you, but be sure to ask about the shipping costs. 1-800-221-0616
            http://www.northerntool.com/shop/too...atchallpartial
            In the search box type in Big Country Fan and that should take you to where you can check out the different models. Because of size and weight shipping and handling would get pretty costly. If you can find one that you can buy and haul yourself you'll save some good $$$.
            You might ask at Home Depot or Lowes as I have now and then seen them.
              Re: drum fans
              got this one from lowes for 239, 3 speed also most were only 2 speeds and yes i need to clean my shop.
                Re: drum fans
                Larry Mullen Jr. and Butch Trucks
