Forum Running Slow?
This topic is closed.
  • Forum Running Slow?
    Have you guys noticed the forum running slow. Every time I check in it seems to be running fine. A few of you said it seems to be a bit sluggish but I wanted to check to see if everyone is experiencing it.
    Thanks,
    Josh
    Re: Forum Running Slow?
    7:30AM no problem logging on
    8:30AM it took more than 30 secs.
    10:30AM over 3 minutes before I was able to get on.
    1:20PM all normal again
    same problem last 2 or 3 days
      I've noticed it running slow on quite few occasions the last 2 or 3 days. Seems like sometimes, not always, it takes quite awhile to get into the site. Once in however everything runs at the usual speed.
      ------- Henry Ford
        it wouldn't load at all at 8 am yesterday for my computer or my phone, then sluggish the rest of the day until last night, when it was fine. then, Mostly ok this morning, a bit slow but it did load.
          Could not log on yesterday morning. Yesterday afternoon it seemed OK.
          This morning could not log on. It seems OK now
            A forum full of plumbers, and not one of you could fix the clogged data pipes?
            :runs:
              on a side note....
              some of us would like a Mobile app. for the Forum
                Ditto on Badger Dave.
                  Same as Badger Dave, mostly in the mornings. Sometimes would not load at all.
                  One thing strange about it. Even when it didn't load, when it finally does later in the day, if you go to new posts the only ones there are after it didn't load correctly. So it thinks it loaded when it didn't.
                  When seconds count, the police are only minutes away.
                    Its mostly in the mornings around 7:30 till 10 it super slow, but then all is well in the afternoon and evenings.
                      Slow to load when coming from another site major, and same problems in the morning of not loading at all. Several days now.
                      Seattle Drain Service
                        The same here, very slow in the morning time but it seems to clear up as the day progresses.
                          Ill see what I can do. Speed problem should be easily fixable.
                          Also.. I think I may be able to do something about the mobile version. just gotta find an afternoon to concentrate on it.
                          Josh
                            That would be spectacular.
                            Josh
                              Speed problem fixed.
                              Will install mobile style sheet on Monday.
