Screwed on warrenty
  • Screwed on warrenty
    Had 3 - screw battery powered drills from ridgid,Had them with 9 batteries for about 6 years.They are 12 volt and dead now..Want replacements like the great warrenty says but no..They have no recall of my registrations for them,They say...Now I need to find my receits for them..Good luck with that..I am upset!!!
    Anyone else been done this way?
    Re: Screwed on warrenty
    I believe that everyone who has improperly registered tools into the Limited Lifetime Service Agreement Program has "been done this way.
    ------- Henry Ford
      Here is a situation I've found myself in. I bought multiples of the same item....but only bought one extended warranty. Is it my job to keep up with the one item i bought the warranty for or the warranty/tool companies responsibility? I can tell ya...if one breaks IMO its going to be the one I bought the warranty on.
        If interested You can rebuild these battery's Yourself.
          It simply never stops does it!!!!!?
          I am so sick of reading posts where some customer buys a cordless tool and doesn't have a clue that
          it's
          NOT A DAMN
          WARRANTY
          YOU NEED TO REGISTER THE TOOL AND THERE IS A PROCEDURE FOR THAT!
          AND IF YOU DO IT PROPERLY
          THEN AND ONLY THEN WILL YOU GET THE
          LIMITED LIFETIME SERVICE
          AGREEMENT
          While I usually display some patience and write an explanation, YOU state that you've purchased three separate drills and "Had them with 9 batteries for about 6 years". So long before now you should have figured out the routine.... so do a search and good luck, I think you are going to need it.
