Torch?
  • Torch?
    Have ya'll seen my torch?
    Thanks.
    Re: Torch?
    you left it on the bumper again.
      Re: Torch?
      Oh, sorry.
      I had to borrow it for a few minutes
        Re: Torch?
        Nice. is that the Rio Grand from the US side?
          Re: Torch?
          JC, I switched to a B-tank when I lost my 4th turbotorch in 6 months. after I lug that big bastard into a crawl space for One damned solder joint, I sure dont forget it.
            Re: Torch?
            Found it in another toolbox. Found my basin wrench too!
              Re: Torch?
              Anyone have one of those lennox torch kits? Torch in a box is what i call them. If so how do you like or dislike it.
                Re: Torch?
                Did you ever think about using an MC tank instead of a B?
                James
                  Re: Torch?
                  I have no idea what an MC tank is. To the GOOGLES!
                  James
                    Re: Torch?
                    is it just a smaller acetylene tank than a B tank designed for a different torch head?
                      Re: Torch?
                      I used to run around with MC tanks, now I carry two B tanks on the truck. Reason for two is it sucks to run out of gas when you are doing up some 2" connections.
                        Re: Torch?
                        He works with Lil' Wayne.
                          Re: Torch?
                          It's size that's used with the small turbo torch type oxy/acetylene kits.
                          James
                            Re: Torch?
                            will it work with the same regulator and torch I have on my B tank? if so i'll check it out. either that or a 50' hose for my existing setup >.<
                              Re: Torch?
                              i have both sizes and regulators to fit both valves.
                              problem with the mc tank is for the amount of gas that's inside, it cost about the same to fill up/ swap out a b tank at my supply house.
                              our supply houses can't deliver any acetylene tanks anymore. the highway patrol started to ticket them as they didn't have the proper licensing to transport the gas.
