Electric power washer advice
  • Electric power washer advice
    I have the Home Depot Husky model 1800S pressure washer.
    I believe it's around 2007 vintage and Home Depot does not support it etc.
    I just lost the turbo wand, the plastic failed and it just blew apart.
    The threads holding the plastic nozzle are gone! So it's unrepairable.
    Plastic self destructs here in AZ....
    I was wondering if I can simply purchase a new metal trigger & wand assembly
    that allows me to simply replace the various nozzles with a quick disconnect?
    Or am I stuck with the Husky plastic trigger and plastic wands?
    Husky does sell a replacement turbo wand unit for around $25.00 but I prefer a metal replacement.
    The unit is rated at around 1800psi and I suspect it would not make any difference what
    trigger and wand assembly I can use....
    your comments?
    Cactus Man
    Re: Electric power washer advice
    Those units were made by (imported by) Faip North America. Here's a link to the OEM parts ordering page:
    Husky Powerwasher
    I'm not aware of a metal wand that will retrofit.
      I've taken the hose off of another broken pressure washer, screwed it onto my other broken pressure washer. Problem solved.
