To you welders
  • To you welders
    Just bought 10 lbs of lincoln Excaliber 1/8" 7018. Reports on weld talk, "Very smooth running" My favorite rod is 7018 for most Mild steel applications . Unless it's Heavy equept. Will run it next week, and report How I like it,
    Re: To you welders
    Been using 7018 for years now for finish welds. It flattens out nicely on the finish pass. Does not have the deep penetration that 6011 or 6013 give but I think you will be pleased with the results.
      Re: To you welders
      I prefer Hobart 418, but alot of guys like the Excalibur rod. It runs smooth, but re-strikes suck, all the flux likes to remove itself from the rod.
        Re: To you welders
        Was burning 7018 this morning welding and makeing some hinges for a platform that needs a section of it to swing up.
          Re: To you welders
          Not good, I hate it when flux starts cracking! I have an LN 22 of My mobile rig. Nice way to go. In the union We used a lot of LN 7s ,structual steel
            Re: To you welders
            i'm spoiled. i've been doing a lot more tig welding and staying away from arc and mig. takes much more eye, hand & hand and foot concentration than all the others.
            but 7018 was always my favorite
              Re: To you welders
              That's Great You learned Tig Rick.
              I have always wanted to learn it. May be some day.
                Re: To you welders
                Oh come on Rick, Chimpanzee's can tig weld, it takes manly skill to burn rod
                  Re: To you welders
                  Well 2 weeks into my welding experience. My Miller 120/240v shoebox size welder is way neat.
                  I keep smoking holes right thru 1/8 " steel plates trying to practice....ANy suggestions of how ya work this little snotty Welder...
                  Using a 6016 stick I believe...
                    Re: To you welders
                    Angle, speed, distance my friend. Never heard of 6016, you sure it's not 6011 or 6013? Anyhoo them suitcase buzz boxes can be a hassle to get set right. If you are burning holes you need to turn the amps down, speed up or both
                      Re: To you welders
                      I'm guessing You mean 6011 AC current rod
                      or 6010 DC rod. You really should enroll in a high school ,or college welding class at night. Pictures posted will help. You may have an acquaintance that has stick welding experience. In little time I could get You into the swing of things. I would show You many little things right off You're doing wrong. I brace myself like a rock for good vertical Beads. Too much to learn on Your own, and You're learning Bad Habits You,ll need to dump. Good Luck, Tool
                        Re: To you welders
                        My son in law was working for a mill wright setting up a grain leg and they were up on the leg welding and they send the help down to the truck to get some more 6011 welding rod, the truck had 6011 and 6013 rod on the truck, any way after a long weight the kid yelled up and said all he could fine was some 1109 rod and could not find any 6011 there was some 6013 tho, I am not sure how much longer the kid was employed after that.
                        but after that the standing joke was get the 1109 rod,
                        This was my welding job on Saturday, the top of the tower platform needed to be modified so it could be lifted by the jin pole and so I made a section of the platform hing up out of the way of the cable and the jin pole, not yet lifted up but soon to be,
