GE Spacesaver Microwave buttons [#3][Clock][Surface light] stopped working.
  • GE Spacesaver Microwave buttons [#3][Clock][Surface light] stopped working.
    Fairly new, little-used microwave.
    We have never pressed button #3 nor most other buttons. Checked and all other keypad buttons work.
    A conductor to the three buttons is open?
    Any ideas?
    Is there a microwave forum?
    Thank you.
    Re: GE Spacesaver Microwave buttons [#3][Clock][Surface light] stopped working.
    "Things" go bad!
    I'd look at the manufacturer's website to see if they have an FAQ or technical bulletin or even technical support. But sadly, most of the microwaves (and far too many other electronic items are simply NOT serviceable... at least at the component level. Most often you simply need to replace the panel or the entire keypad circuit board behind it.... if one is even available! Contact the place where it was purchased or try to find the manufacturer. Either way, I'm betting they are not going to be user serviceable.
      Try this link. Keypad number buttons not working on ge spacesaver microwave - - FixYa
      There seem to be many links to address this problem, best of luck. Frank
        I will take the board out to see if a solder joit is open.
        Never had problems with GE before.
