Anyone re build a cat pressure washer pump ?
  • Anyone re build a cat pressure washer pump ?
    Have 2 different Pres. Washers. one is 2400 lbs and is only putting out 900 psi. If I can find a Kid shouldn't be that hard.
    Re: Anyone re build a cat pressure washer pump ?
    check for dirt in the 6 caps/ check valves.
    is the oil water free?
    any leaks from the pump head?
    is water bypasing the unloader through the bypass hose?
      Thanks Rick ,Great info
        I have repaired thousands of water pumps. I tried one Cat pressure washer pump. I got into it and got right back out. Totally different that what I'm used to. Looked like some special tools may be needed also.
        It's probably a job best left to the pro's with experience.
          What model and whats the serial? I can get a new seal for you if you need one, I am a master distributor of US Seals.
