Curb C0CK Wrenches
  • Curb C0CK Wrenches
    Every once in a while I make some curb C0CK wrenches. I know you guys up north in cold country have/make them longer. But, down here 30"/36" is plenty long enough..
    I paint them bright colors so they don't get lost in the grass.. Usually what happens is my customers leave them behind on the job site...
    Re: Curb C0CK Wrenches
    You're right, 8' and longer is common around here. 3' ones wouldn't even get half way down to the curb stop.
      3' is great for residential here but I have one for gate valves that can extend to 12' - 15'. I hear some cities have motorized wrenches for exercising their valves.
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
      • conductor fault locating
      • and other specialties.
        The water company here flips out if you touch the curb stop
          all cities are a no no to touch, but santa monica is a real no no no. they will respond usually within 15 minutes.
          i even have the 2'' corporation wrench for large meters and hydrants. but it stays at the shop with my telescoping ratcheting extendable 6' center tee handle ridgid underground tank wrench.
            Not here in the Tampa Bay area.. If you need to shut it off we have thier blessing..
              here is the parts breakdown of the wrench i'm referring to. keep in mind that the handles are 6' long and the drive shaft is 2'' square tubing like a trailer hitch.
              http://ridgid-belarus.com/files/prod...tankwrench.pdf
              need to dig up my photos of the wrench
              6' in length ratcheting handle with telescoping extension, 2'' corporation adapter, hex bushing adapter and chain wrench on the 2'' drive.
                I have fabbed 2. Now for the city key this is how I'll copy the lug head. Tack weld a large socket on a length of re bar. I'll fill the socket full of wax ring wax or plumbers putty.
                Perfect Impression! Will fab from there. Never should of said NO NO TO THE IRISHMAN !
