Redgard vs Morter Mixed with Acrylic
  • Redgard vs Morter Mixed with Acrylic
    Sorry if I am not posting this in the correct place, this is my first post. My contractor wants to use morter mixed with acrylic to cover the screws that he drilled into the Hardibacker he is using for my shower. I keep reading about Redgard. Should I insist on Redgard or just let him go with morter with acrylic. Please let me know your opinions ASAP. Thanks!
    Re: Redgard vs Morter Mixed with Acrylic
    Thinset is fine to cover screws if it is on the walls of the shower/tub surround, aslong as your not doing a steam shower and as long as your above the pan. Most CBU manufactures recommend thinset over the screws/nails, and thinset set in fiberglass tape on the seems.
    Will Rogers Plumbing
    Moore, Oklahoma
    405) 323-2852
    www.willrogersplumbing.com
      I say do it right the first time.
      Use Redgard and never have to worry about the job!
      Cactus Man
        Redguard is a paint on moisture barrier. Mortar is simply masonry with no moisture barrier capabilities. What has been/is being used in your shower as a moisture barrier? You need something - you cannot just use backerboard and expect it to be water proof.
        I would suggest you head over to the John Bridge forum and ask your question there and possibly in more detail in case a moisture barrier has not been used - that's not the correct way to build a waterproof shower.
          I will no longer install any bathroom tile, tub, shower, hell even the floor without redgard installed behind it. It's cheap insurance. I've had contractors complain that it adds time to the install, I tell them to bad, I don't care, I don't cut corners.
            No reason to install Redguard on the walls of your shower. Doesn't have to be waterproof there. Use Epoxy/Urethane grout if you want to go above what the norm is. If your going to use a waterproofing membrane go with Hydroban or Aqua defense. Redguard is the worst membrane you can buy. It will just pill right off once cured.
            Moore, Oklahoma
            405) 323-2852
              You need something - you cannot just use backerboard and anticipate it to be waterproof.
              Landscape Paintings
              Van Gogh Paintings
                What in the world?
