lennox pulse furnace
  • lennox pulse furnace
    I have an older lennox pulse furnace and there is a water leak coming from a little green box, located on the backside, near the top the furnace. This green box has a small metal pipe , about an inch long, coming from the bottom (this is where the water is coming from).. there is also a type of turning knob near it...on the top of the box is a copper tube that . once i follow it, seems to join my water supply .. What is causing this water leak and why is there water in there to begin with? ( model # G1403-80-C3)
    Thanks
    Re: lennox pulse furnace
    pulse furnaces do not have little green boxes on the back rear of the unit. you probably have an ancient humidifier that has a float problem. over the years hard water causes it to not seal. follow the water line to your water supply, there should be a small valve that you can turn off. if the handle doesnt turn, dont force it. it can snap off. call a qualified plumber.
      I think you need to upgrade your firefox into latest version.
        I think you need to upgrade your virus and spyware checker.
