Basement egress drainage
  • Basement egress drainage
    I have a 9-year old house with an unfinished basement that is completely below grade. In order to finish it, I need to install Egress. My preference for egress is a door because the current basement stairs (inside the house) will not accommodate pool table/large furniture/etc... My question is about drainage from the outside stairwell that I will need to construct. My contractor wants to bring the drainage (rainwater, snow melt, etc.) to my existing inside sump, which I don't believe has ever had a drop of water in it after nine years. I am extremely averse to bringing water into the house. Is there any way to install a sump pump beneath the stairs that I won't have to worry about freezing? I live in the Philadelphia area, where temps routinely dip below freezing in the winter, and potentially for weeks on end. HELP!!!!!
    Re: Basement egress drainage
    Have you considered using something like this? It is at least as waterproof as your current foundation and if you have not had a basement water problem in 9 years why would the contractor want or need to install drainage if he used a system like this? If he is pouring concrete in place, then drainage would be an issue. When he excavates the hole for your egress door, maybe a dry well adjacent to the excavation would work.
    PermEntry® Basement Entrance - Detail information for PermEntry® Basement Entrance
      All Us M*******S KNO OF BILKO
        this would be my recommendation too. i had one on my last house and never leaked a drop in 8 years.
        i will say that the only thing I didn't like was the noise of rain hitting the Bilco when you are in the basement.
        If I had added a second, insulated door at the foot of the stair it would have stopped that and the cold air that came from the stairwell. If I had stayed I would have added the door, and looking back I should have been smart enough to do it right from the beginning, so learn from my error and do it now, even if you are in a warm climate it will be added security and looks nicer. My basement wasn't completely finished off and I never spent any time back where the door was. All I had was my ham shack in the other half so it never bothered me, but it sounds like your case will be different.
          You may be able to get a multi-panel Bilco custom made from a metal shop or local welder (picture 4 bilco doors than lap over each other like roof shingles). This way would allow for a longer ramp into the cellar instead of stairs. A nice feature if you want to drive stuff into winter storage.
