26 degrees here in marin calif. !!
  • 26 degrees here in marin calif. !!
    We have an email for the area , Lost Kats,kids bikes for sale ,burglarys, ect. One neighbor just posted " No water in
    house.I think My Pipes are re routed on roof ! Today will be Busy ! Slab on grade homes, instead of cutting slab for repair, some chose to re rout on roof ! Bad decision ! Good for plumbers !
    Re: 26 degrees here in marin calif. !!
    The spring for our water company in Utah is at -13 degrees this morning. I'm guessing our T-Chlor up at the Chlorination station is frozen. I sense our water operator is going to have a long day.
      Upper 50's here in CT, but cloudy. I'm not complaining if we don't get a bad winter. Had a couple neighbors with slab heating that failed, they had baseboard done as a repair.
        As I type this, it's 18°F outside. It's also December in WI so all is normal! Also, the smilee feature doesn't seem to be working, must be too cold out!
        I'VE DECIDED I'M NOT OLD, I'M 45 -- PLUS SHIPPING AND HANDLING.
          And I have to crawl under a wet house this morning. Hot return line pin hole. Hopefully I can press it if the pipe is decent. Otherwise I'll break out the torch and warm up the place.
          Rick.
            64 degrees here...hahahahahhaaaa
            wont last long though
              NOAA National Weather Service.
              Actually broke a sweat today.
                66 today, but a chance of snow for Sunday.
                Tool I just re-piped my slab on grade house & I ran everything in the interior walls. Only had to go in the attic in (1) short run & it's under 12" of insulation with a shut off before it goes into the attic.
                  Right now it's 52 degrees here in Binghamton, NY. But as is too often said around here, "If you don't like the weather, wait a minute!" By Saturday it will be donw in the low 30's for the day and in the teens by evening. I've already had to shovel snow a couple of times this year.
                    you rat !
                      Good for You ! We can't do that . Our Eichler homes are one story post and beam homes.
                        Just did one pipe burst on a roof. Foam insulation is shot N old. Will insulate with the 3/4" foam.
                          did you sell a patch or the comfort of a pipe that will flex with frozen water and contract when thawed (pex)?
                            Was 71 when I got home from work yesterday afternoon
                            Went down hill all day today its 33 and dropping with freezing rain coming
                            Not looking forward to the low teens and no power
                              Right now we are around the zero mark and with the wind chill -24. Add a few days of snow and its all fun. Can't even use the snow blower as it won't start and the repair shops are booked solid for the next few weeks.
