How does the saying go?
  • How does the saying go?
    You can do it good, cheap or fast. Pick two? It's something like that.
    Re: How does the saying go?
    Fast, Good or Cheap. Pick two.
      and no good deed goes unpunished.
        Should be the slogan for the PEX industry
          PEX,any good stuff about it /
            Asking because I see it all the time.I repiped one of my houses with,and a job or two where it was the best choice for the customer's money and for my time involved.I try to stick to drain cleaning only,as my pickup is not large enough for lots of material,and I dislike running back and forth to part stores,besides I no longer wish to have a cramped /cluttered truck.
            So,just would like to ponder your{or anyone's reason's}again.
              Time, Cost, or Quality...pick any two but you can't have all three.
                Copper Pipe
                Advantages:
                1. Resists corrosion more than other metals like steel or brass.
                2. Can be used outdoors, unaffected by sunlight (UV).
                3. It’s fireproof and doesn’t release toxic gas in case of fire.
                4. Recyclable.
                Disadvantages:
                1. Average cost of copper pipes is 4-6 higher than of the PEX pipe.
                2. Water could have metallic taste if copper is corroded.
                3. New copper plumbing systems may require chemical treatment to remove leftover solder from brazing the joints.
                4. Copper pipes are high likely to burst when water in the pipes freezes.
                5. More difficult to install than PEX tubing because of its rigidity, requires more PEX fittings and connections.
                PEX Pipe
                Advantages:
                1. Requires fewer fittings, easier to install, less likely to have a leak.
                2. Very cost effective, requires less labor.
                3. Can have long continuous runs without the need for couplings.
                4. Is able to expand and contract making it more burst resistant than copper, brass, and other rigid pipes.
                5. Has good chemical resistance.
                6. Pipes can be bent around almost any corner without an elbow fitting.
                7. Quieter, reduces “water hammer”.
                8. Recyclable mechanically, chemically, and thermally.
                Disadvantages:
                1. Can’t be used outside.
                Your turn
                  Boy did my thread get hijacked!
                    Originally posted by MR.FUDD View Post
                    Disadvantages:
                    This is false. Pex with a UV barrier can be used outside, or underground.
                      In my experience, AT BEST you can pick only two. Usually have to settle for just one.
                        http://www.uponorpro.com/~/media/Ext...n=100120121018
                        Enough Said!!!
                        I wonder when the Copper Institute will match that?
                          Most of them do.
                            How does the saying go "To be or not to be that is the question"
                            Tony
                              Sorry.
