this has been addressed several times...
  • this has been addressed several times...
    on and off on this board. the problem with rust forming on the cast iron table tops/tables of our tools. There are several products out there, many use wax, many use Bostik Topcote (that is what I do). I was introduced to a product that may work better than all of the above. I just got a can tonite. The product is called "corrosion block" and it is made by a company called lear chemical. I just got a can today, the explination on how it works is fascinating. I will let you folks know how well it works. Apparently you can treat something that is corroded and it will clean it up pretty good too! I'll let you know
    http://www.learchem.com/C.B.Page.htm
    Well
    So far I am impressed. I had a rusted chip breaker that i tried this stuff on. Sprayed it on and left it set overnight. No scrubbing brushing or anything and 75% of the corrosion is gone.
    I will be doing a before and after photo here on another item. So Far I am very impressed!
