wet dry vac model1635
  • wet dry vac model1635
    I was wondering if it is ok to use the filter that comes with this unit to suction saw dust(or is there some other special filter that i need to use?)
    the owner's manual makes no mention of using a 2 stage filter. and when i contacted tech support, i got mixed answers on this.
    i had a wet dry vac(shop vac) burn up on me when using a 2 stage filter, so I am a bit leary of adding the extra load.
    thanks
    The single stage filter that comes with your vac will work just fine for sawdust collection. The 2-stage filter is needed when vacuuming very fine particles such as drywall and fireplace ash.
    The most important thing to remember when using a vac as a dust collector is cleaning the filter on a regular basis.
    Jake
