Jointer Dust Chute
  • Jointer Dust Chute
    Am i the only one experiencing a hastle with the dust chute on the Ridgid Jointer? Mine cloggs up completely after about 10 or 15 min of semi constant use. i usually have to vaccuum it out with my shop vac. Is this a common problem? How effective is the dust collection adapter when used with a shop vac?
    ed
    Ed,
    Do you have a JP0600 or an JP0610? With either unit make sure you do not have the plastic dust collector adapter in place. On the JP0600, you need to remove it, on the JP0610, simply loosen the screws and slide it up out of the way.
    Jake
      JP6010 and yes the black plastic adapter is in place. will remove it and let you know. thanks
        sorry for the delay. yes the chute was removed and it is no longer clogging up. thanks
