Oils
  • Oils
    doing some research on oils that are/were in the past used for honing. One of the choices I see posted a lot for the natural stones is "sperm oil" which is apparently a non petroleum oil extracted from the blubber of sperm whales. Anyone know if this stuff is still readily available? In addition, someone recommended the following as a substitute : An inexpensive, effective substitute for sperm oil is Dexron III automatic transmission fluid. Anyone got an opinion on this? Anyone know of a source for sperm oil?
    Another possibility is pure neatsfoot oil? Not the commercial stuff you buy today for shoes, but the pure stuff you can apparently biy at tack stores, used primarily for saddles these days.
    Any input/comments on either of these 2 would be most appreciated
    I'm not going to type that into a search engine at work
    Since whaling has been banned here for quite some time I think the only source would be the orient. I think you want a thin lube for stones which is why many still use kerosene
      Well
      After researching this....
      it turns out i have been using it all along. Aparrently Smith's non petroleum honing compound is a synthetic "sperm oil" with additives to keep the stone clean!
