Parts replace
  • Parts replace
    One of the caster wheel broke on my wet/dry vacuum.How do you remove the wheel caster from the base drum (16 Gallon Detach Wet/Dry Vacuum WD16600)?
    unless it is one piece, you should be able to get it off with q few smack's with a dead blow hammer
    also check for a screw above the caster, you might find one. good luck
