Pictuer is worth a 1000 words
  • Pictuer is worth a 1000 words
    Dave A, just took a look at your "no left saw cap."..what happended do you CUT it off. Like the push stick handle. Is that a router station attached to the saw top wing ? THanks for the pic. dd
    Glad you like the picture.
    Here are a couple others that might show the setup a little better:
    http://users2.ev1.net/~arbuckle/ripping/30900
    01.jpg http://users2.ev1.net/~arbuckle/ripping/DWAshop06.jpg
    What that is, is an Incra TSIII fence. It installs on brackets in a T-slot (like the stock Ridgid if I recall correctly), so the rails can be set where you want them. Mine has a maximum capacity of 52 inches, at the expense of a very wide footprint.
    Yes, that is a router table built in. It is a way to leverage the cost of the Incra against two uses.
    I'm proud of my little pushstick. It's my own design.
    Dave
