Suggestions for Jointer Manual
  • Suggestions for Jointer Manual
    I found at least 3 things irsome about the otherwise very good manual.
    1 - graphics are poor quality - improvement would help.
    2 - Manual says to install the blade guard. A step or two later it has to be uninstalled to check the blade height settings and then reinstalled. A sequence change would be in order.
    3. - Pulley guard should not be installed untill after fence table height is adjusted and blades are adjusted.
