10" miter saw ...need 3 little parts.
  • 10" miter saw ...need 3 little parts.
    In jan 2004 I purchased a ridged 10" lazer miter saw.It was working great untill bolt that holds table to base fell out, never to be found
    .Allowing it to move all over. I tryed to fix it to finish job . But thin metal 1/2 circle glides became bent and unuseable.No service within 15o miles just need 3 parts will fix it myself.
    Check the parts diagram in your owners manual and identify the parts and part numbers that you need. Once you've done that, you can order the parts from http://www.ordertree.com
    All of us could take a lesson from the weather. It pays no attention to criticism.
      Sounds like you popped out the table shims. Double check your manual for the part and part#.
