Which lubricant do you prefer?
    Re: Which lubricant do you prefer?
    I protect my tools with a couple layers of rust to protect the metal underneath.
    Ok, seriously, I have no particular preference and tend to use whatever is handy or what it better suited to what I need. WD-40, Tri-Flow, Boeshield, and and assortment of greases, whatever is best for what I need.
      heheheh ky gelly is good for some things too.
      ps couldnt resist please forgive me
      §m€llŸ™
        For me it would depend on the use. Something I do use a good bit of and for many things is GIBBS which comes in a pressurized squirt (not spray) can. It's a bit high in cost, but has been a big help. It's my #1 Loosen-Er-Upper anymore.
        http://www.usalubrications.com/gibbs.html (You can read up more on it here)
          I use tri-flow this is a lubricant with Teflon this stuff loosens rusted hardware, frees sticky mechanisms, washes away dirt and contaminants.
          I found this stuff at ace hardware
          I also use slip sliding compound..this is great on the table saw
          This found at woodworker's supply#909-314
          this stuff is also great to lubricate dresser drawer wood slides.
          it's non-toxic, inhibits rust and corrosion, attracts less dust.
          I use wd-40 to remove glued labels
          Cactus Man
            Hey I know... what's slicker than --- pupshit!
            Dura-Lube in a spray can is something that works quite well on anything squeeky
            Most people don't realize that WD40 is a solvent , it will free up sticky parts but it's no good as a lube... Once upon a time I learned the hard way as I was using it on the chain of my mountain bike, I wore that sucker out quick (tweren't a cheap chain neither )
            Cheers! - Jim
              Best thing for bicycle chains is to cook them in hot wax.
                Yep, found this out after a little research that time
                (same research that informed me that WD40 is a solvent)
                The melted wax seeps into every little crevice between the rollers etc.
                The great thing about the wax is that no dirt will stick to it.
                It's also nice to work on yer bike and not wind up with black greasy hands
                Cheers! - Jim
                • #23
                  You can't go wrong with WD40. Plus you can find it just about anywhere you go.
                  • #24
                    you definately CAN go wrong with WD 40
                    West Trail Mechanical Ltd
                    www.westtrailmechanical.ca
                    • #25
                      i've not found any lubricant that works in cold, dry climates.
                      we strip our firearms and handtools of all grease and oils.
                      it's the only way they'll work.
                      Vince
                      • #26
                        KY with tingling sensation.....was that TMI?
                        • #27
                          Vince
                          Military uses stuff called LAW-lubricating artic weather. Never used it but they say it works.
                          • #28
                            CLP / Breakfree, All of my plumbing tools get hit with it
