Joining copper to PVC or ABS
  • Joining copper to PVC or ABS
    What's your preferred way of joining copper dwv tubing to PVC or ABS?
    A) Fernco
    B) No-Hub Coupling
    C) Missionary Coupling
    D) Desanco Fitting
    Marcus Rinaldi<BR>Service Tech<BR>F&W Heating & Cooling
    Re: Joining copper to PVC or ABS
    adapting no hub coupling, copper x ips
      A) Fernco
      B) No-Hub Coupling
      D) Desanco Fitting
      survey says a- fernco coupling.
      i'll have to try that missionary coupling soon
        I'm not sure what a missionary coupling is Rick but I have used Mission couplings. I figured you knew better than that.
          have lots of mission couplings, but it's that missionary coupling i'll have to look into getting
            I'm sorry Rick I didn't mean to have fun at your expense. There is actually not a Missionary coupling. I believe what the OP was referring to was in fact a Mission coupling. I hope that helps and you don't spend too much time looking for a Missionary coupling.
              500 for c alex
                Missionary couplings can only be used horizontal
