Rigid 4 gallon wet/dry vac - spewing water
  • Rigid 4 gallon wet/dry vac - spewing water
    I use my wet/dry 4 gallon vac every six months to drain my electric countertop Ariston water heater, I kept noticing water would spew out the exhaust port on the side of the vacuum when it did not seem even half full - what am I missing here?
    Typically with wet pickup, only the foam filter is used, not the paper filter. Also if the float inside the cage is sticking or dirty, it can overflow.
    what filter are you using?
    Rick.
