Wet vac markings
  • Wet vac markings
    hello ok so I use a ridgid wet vac to strip and wax my floors however this last time the hand held attachment with the squeegee on the end left horrible lines on my floors has anyone else had issue with this or any suggestions to stop this from happening again
    thank you
    Arm chair troubleshooting:
    1. squeegee is worn out replace the rubber squeegee part.
    2. Debris is stuck on squeegee clean it and wipe with alcohol.
    3. weird floor and is not smooth causing the squeegee to leave lines.
    4. you are pressing down on the squeegee too hard or the angle of squeegeeing is wrong.
    Cactus Man
      Could the rubber be breaking down with the floor stripping chemical. just like bleach will do to rubber.
      Rick
