Ridgid 10" wet tile saw
  • Ridgid 10" wet tile saw
    Just picked up the Ridgid 10" wet tile saw (coming from a 10 yr. old 'ridgid saw) and once I got everything put together, there is a noticeable notch or bump every 4" or so when cutting tile. Has anybody else experienced this issue? My old saw did the same thing but not as bad and I just learned to deal with it but this actually hinders tile cutting.
    Thanks!!
    Every 4 inches. Think of what might be rolling that has a circumference of 4 inches, something about 1.25 in diameter, which sounds about right for the wheels on the carriage. They may have a casting flaw or something else that creates the 'bump' every 4 inches of travel. Find it and smooth it out and you should be good.
    • Twrecks700
      Twrecks700 commented
      Editing a comment
      That's what my initial thought was but the unit is brand new. I would expect it to be machined correctly!! I will check first thing tomorrow and if it's defective, I will definitely be returning it!!
    Could be a bit of packing material stuck in there. It's like a shopping cart with a flat spot on a wheel or a lump of bubble gum stuck to a wheel, very aggravating.
    • Twrecks700
      Editing a comment
      Exactly like a flat spot on a cart!! I've checked for any and all flat spots or abnormalities and I can't find anything obvious so I will be exchanging the saw today. Bummer.
    If not visible on the external part of the wheel then it must be a bad wheel bearing then or axle, which is probably nothing more than a bolt or pin.
    If you could figure out which one it is maybe you just need a replacement wheel and/or bearing. Sound easier than dragging the whole saw back to the store.
      Swapped out the saw for a new one and the new one works great!! Never could figure out why it was notchy but the flooring guy at Depot even said that ain't right!!
        Good, glad they took care of you without much hassle.
        It's bad enough you have to drag that beast back to the store.
        Good luck with this one, I hope it serves you well for a long time.
