Multi-Material Saw blades
  • Multi-Material Saw blades
    using the metal blade to cut 1/8 x 3/4 inch aluminum. Could only cut thru 1 time before blade crapped out. Blades don't last very long.
    My experience:
    Do not force the cut. Let the weight of the tool do the work.
    If you "force" the cut by pushing the blade will fail quickly.
    Also speed of cut may effect blade life, so if you are cutting at
    max/high speed try slowing it down and see what happens.
    Typically, like drilling metal you go a slower speed than drilling wood.
    The same applies to multi-tool blades cutting any metal
    There are better quality blades out there but cost more.
    What brand bade were you using?
    cactus man
