Analog Multimeters
  • Analog Multimeters
    If you’re like me, you probably have a small collection of digital multimeters (DMM) that are suited to different types of measurements. As you know, a DMM shows results as numbers on a screen while an analog meter uses a needle to show the value. Analog multimeters are a thing of the past for most of us as modern Fluke DMM’s have dominated the market over the last couple decades.
    However, working on a variable speed electric motor, I was just reminded not to discard my old analog meter. It still has its place. An analog meter has the advantage of being able to show a changing signal. Watching a needle move up or down is a lot more intuitive and easy to interpret than trying to track the changing numbers on a digital display.
    If you’re old enough to remember that Red Skelton was a TV comedian, you are probably familiar with the vintage analog models like the Simpson 260 and Triplett 630. I’ll be keeping my old Simpson.
    IIRC, analog meters offer less resistance to the circuit, and are preferred for radio-like circuit measurements (it's been a long time, so I hope I got that right). I still have a couple of small, hand-held analog meters and one larger bench-top 'multi-meter'.
      IMO to observe a changing signal a scope is a better tool than an analog multimeter. There are some reasonably priced small low bandwidth scopes around. I have one in my toolkit to observe waveforms on motors and inverter drives.
      • AverageHomeowner
        AverageHomeowner commented
        Editing a comment
        Agreed if you need a lot of precision or want to save the waveform for future reference. I have a hobbyist-class Picoscope I picked up on eBay. It's only 2 channels and I've been looking at the Hantek's as an inexpensive scope for 4+ channels. Some handhelds have screens that display waveforms, which might be what you have, but I prefer the USB scopes with the larger computer screens to see all the details.
      • blue_can
        blue_can commented
        Editing a comment
        Yes I'm familiar with the Picoscope. The one I have is is one which displays the waveforms on a screen and is also touchscreen. I use it in the context of HVAC field work for diagnostics. I like the portability.
        Since I also design electronics and chips for a living I use a lot of high end high speed scopes but thankfully these are usually supplied by the people I'm doing work for so I don't have to pay out $10K+ for one. I did attend a seminar a while ago where they had a drawing for a really nice Agilient high end scope which was also a spectrum analyzer but sadly I did not win it. The one I have supposedly does do FFTs and can display the spectrum of a signal. I did look at the FFT of a squarewve and it does look correct but not really good enough quality for any sort of comms system design or rf work.
