Why did the size of the edit box change?
  • Why did the size of the edit box change?
    Josh, some time ago, maybe three weeks, the size of the reply edit window changed from the old 70-some characters to what is now only 36 characters wide(see below).
    I don't know if anyone else is seeing this but it appears this way to me on three different computers, so I don't think it is a setting on my end but more likely something that changed in the forum software.
    Re: Why did the size of the edit box change?
    bob mine is the same way but my son is always playing with the setting on here so i just thought is was something he did to it...... oh well
    9/11/01, never forget.
      12345678901234567890123456789012345678901234567890 1234567890123456
      1 2 3 4 5 6
      still 70 wide for me???
        it likes you more.... lol now try the quick reply button
          Mine stayed the same here as it has been. If you want, click on UserCP and then on Edit Options. Work down and you can select from 3 editing modes. Maybe you'll like one of the others better than the current setting. I use the middle default editor over the WYSIWYG editor.
            Yes, when I use the Post Reply button on the left Click image for larger version
ID:	615332 it works as it always did. When I click on the Quick Reply button Click image for larger version
ID:	615333 on the right it starts to display at the normal width then quickly shrinks down to 36 characters wide.
              Yep, you are right Woussko. it appears it only occurs when the WYSIWYG editor is selected. I went to the User CP and set it to standard and everything worked fine, went back in and set it to WYSIWYG and it is back to only 36 characters wide.
                Same here Bob ... Crazy ... I'll just put up with it as is for now.
