toilet rings - wax or foam
  • toilet rings - wax or foam
    I had my first adventure in plumbing this week. I went to tighten a loose tiolet bolt and found out that it would not tighten.
    I hestitiatly (after doing some research) removed the bowl (scary for a plumbing rookie) and had to intall a "repair flange" over the existing broken flange. This raised the toilet a little and i did not need both of the 2 foam rings the plumber istalled previously.
    The dilemma comes with the rings themselves. Which is better to use? the wax ring seems a good choice (perfect fit), but so does the foam (no mess, easy to install).
    Is one inherently better than the other or is it a case of preference?
    I have used both without much of problem. I like rubber gaskets better if you have to stack them otherwise i generally use wax
