Ice maker
    Re: Ice maker
    The reason the fitting keeps turning and turning is because you are trying to compress the metal sleeve (ferrul) to make a watertight connection. You will need to use two wrenches on the little "union deal". One to tighten the nut and one to "back yourself up". Put one wrench on the middle of the fitting as that part does not move, and use the other to tighten the nut. Try that and you should be able to get it tight enough. Make sure you do not over tighten the side with the plastic tube so you don't crush it.
      Re: Ice maker
      i have no ideas about ice makers but i love appliances so just try to make some research and experiments with your ice maker.,
      _________________
      Ice Machine Parts
