Ice maker
  • Ice maker
    Hi,,yes I am a woman but not your average one,,i can do a few simple house hold mending chores. Anyway i have an icemaker that i want to hook up,,there was one here previously and the guy cut the copper tubing when we took out old fridge,,so i have the tubing already run,,i had to cut the pipe so i could put new fitting on,,got it all hooked up and it is leaking at connection...i did not use a flaring tool for the simple reason did not know for sure what it is or does,,can you help me out a little,,i have just conntected copper tubing to plastic tubing using hardware ,,nut bolts,,ect from lowes,,went together good but the threaded bolt on the copper tubing side seems to just go round and round wont tighten up...thanks for any help!!
    Re: Ice maker
    I assume that you are trying to connect 1/4" copper line to plastic line
    If so you need to use the proper compression coupling which has sleeves that you must slide over the lines to make a water tight fitting...
      Re: Ice maker
      the easiest fitting that a homeowner can use on a transition from copper to palstic is a fitting called a "jon guess" coupling or union. just cut the tubing clean and slide the 2 ends together.
        Re: Ice maker
        I am using the little union deal,,and it just keeps turning around,,wont stay in place and yes i am attaching to plastic tubing
          Re: Ice maker
          Your little union deal,is it a compression union,or the flare.
          The people here can get you through this,is there a reason why the jon guess isnt working,they work really well.
          If for some reason this is not an option.Again,what pipe size are you working with.
          Is this for a regular home freezer with ice maker,or for a large commercial ice machine.
            Re: Ice maker
            if you can take a photo of it it will help to
              Re: Ice maker
              Ok guys,,you could call me a dumb blonde except Im a red head,,but I think I finally got it,,I had the right parts but just didnt have it tightened enough. I came back and read your post and was going to take pics for you when I decided I was gonna try it again, wasnt gonna let it get me. So it is hooked up now and if there is any water coming out I dont see it,,but it may still need a little more tightening as it kinda looks as if it may be seeping out a small bit but I will let you know tomorrow,,I have a bucket under it just in case....Now can ya tell me how to turn up my hot water heater????,,,,Thanks a bunch and I will be back.
                Re: Ice maker
                Turn the knob to hotter, keep in mind your not recomended to go over 140deg F. There is a way to go over the manufactures settings.But not a very good idea leave that for the pros.
                Tyler
                  Re: Ice maker
                  Make sure it's not a flare nut to a compression fitting. Most icemakers use a 1/4" compression fitting. What size pipe do you have sticking out of the floor or wall, and where is the shutoff valve?
                    Re: Ice maker
                    Well try search in the internet and find some site that can help with your problem about ice maker or try to get information in ice industry maybe you can pick some tips or idea to solve your problem in your ice maker stuff...
                    ____________________
                    Scotsman Ice Machine
                      Re: Ice maker
                      at the risk of trying to be helpful.
                      http://www.youtube.com/watch?v=QrqwfoLHkVk
                        Re: Ice maker
                        Those self piercing vavles are garbage!!! Talk about elecrolysis!! I have yet to see one installed that isnt rusted beyond recognition after a year!! Cut in a tee, then a 1/8" comp. angle stop and do the job right!! Id rather use a sharkbite than a self piercing valve talk about liability!
                          Re: Ice maker
                          Tyler
                          I had to go back to a install the customer said he had the heater at 140 degrees but the water was not hot enough. I put a thermometer under the faucet and it was 140 degrees. First I asked if he had diabetes that was a no. Good cuz I can't fix that. Then I taught him to turn the hot water on all the way to let it get hot before setting the temperature with the cold.
                            Re: Ice maker
                            I agree about the self piercing valve. I attempted to shut my down because the water line in the fridge door froze up. When I closed the valve it would not seal and leaked continuosly. Garbage is right!
                              Re: Ice maker
                              The first plumber that I worked with when I was a helper was a woman.
                              They told me I'd be working with "Joe", so I thought I heard them say. When Joe got to the shop, I learned it was Jill.
                              Not scared to get dirty, the only problem she had was lack of upper body strength. She was cool though. I watched her one time reach into a dirty toilet, something I've never done.
                              I hate 1/4 inch soft copper, most common pipe fittings for leaking, for me.
