gas leak
    Re: gas leak
    I am not a plumber. We had a similar problem at a place I used to work at. The gas smell was coming from the outside pressure regulator. I do not know if it was leaking or venting from overpressure, but when the wind was out of the south (in our situation, as this was where the regulator was on the acft hangar), the smell was so bad inside we shut down the hangar until the fire dept and plumbers had checked it out. Final fix was replacing the regulator. This was after they found several leaks outside with the soap/water test method and had repaired them also.
    My point is that if is is an intermittent problem, it could be an outside problem that is getting blown inside due to wind direction, etc.
    Just an observation
    Go
      Re: gas leak
      garager as much disagreement me and dog might be having i would have to say he is 100% right on this, he knows his job and knows it well so please listen to him on this.
      9/11/01, never forget.
        Re: gas leak
        Thanks for the compliment chevy, but if I'm ever down south, which I don't plan happening (I saw "Deliverence"), I'm taking you up on your offer.
        We could kick each other's asses around for a while, then become friends over a case or two of beer. And you know what?....I really think we could be friends.
        the dog
          Re: gas leak
          make it root beer and i'll join you all
            Re: gas leak
            aww i would rather for go the whole butt kicking thing and i know i will pass on any "deliverence" moments and i thought that was filmed in west virgina?i might be wrong on that.... ohh great now you have my mind wanting to know and now i will have to research it. grrrrrrrrrrr. oh and my name never has been nor ever will be nead batey(i know i know learn to spell i know) and only 2 cases? dang man you can stay longer than an hour cant you?lol peace.
              Re: gas leak
              no that is ned beaty and it was filmed on the chattooga river in georgia.
                Re: gas leak
                Next time you smell the gas, check the vent on your gas meter.
                • #23
                  Re: gas leak
                  I had a problem like this a few weeks back on a new construction job. It turned out to be the burner tube coming out of the gas valve on the water heater and would only happen when the water heater was in use.
                  Small leak, might want to give it a look.
                  ________
                  Vaporizer Affiliate
                  Mike
                  • #24
                    Re: gas leak
                    This has been a discussion that I find hard to believe was ever brought up it the first place. Gas goes boom. You smell gas, you call the gas company. You don't screw around with it and ask questions online. YOU CALL THE GAS COMPANY before the whole damn house heads for the sky.
                    • #25
                      Re: gas leak
                      Gas company will shut you off. call a plumber . what i do is if the line is leaking i change from the meter to all fixture .
                      • #26
                        Re: gas leak
                        NO YOU CALL THE GAS COMPANY. Its a liability issue. They will send out a service tech to fix the leak.
                        • #27
                          Re: gas leak
                          Another related but not quite the same question. Let's say your CO detector goes off. AFTER getting out of the house who do you call. The fire department or your oil company? I think on the package it says to call the FD, but what can they do?
                          • #28
                            Re: gas leak
                            I agree with the person that mentioned the regulator, the vent is for relieving pressure. I didn't catch if the meter and regulator were outside but the vent should be run to the outside. I can't imagine that the gas company douldn't suggest that as I work for the gas company
                            • #29
                              Re: gas leak
                              out here a lot of people call 911 and get the fire department and we have all kinds of meters and then the FD will have the dispatcher call the gas co and they will respond faster for them then a home owner
                              the FD gets there faster and can shut off the gas and vent the house .
                              out here the gas co will look and fix a gas leak but they cost a lot of $ so people will call a HVAC co to do the work ,and if the gas co puts a lock on the meter the HVAC contractor has a key for the lock and can take it off then have the gas co come back to check the work . to get a key you have to go to a class from the gas co first
                              but i'd say if you checked and the gas co checked the lines then it must be a vent . there are times when the gas burns a red flame and not blue ,there is something with the gas and you will get a smell like gas .
                              • #30
                                Re: gas leak
                                There are so many places where gas can leak . . .
                                The meter vent sounds most likely to me - I smell gas all the time from the neighbors when the air is heavy. And that may be a clue to when you're smelling gas.
                                Another place is worn-out valves on a stove - the little ones beneath the knobs.
                                Ground-joint gas valves are a very common leaker - usually tightening the nut will solve it.
                                I like the liquid leak detector better than soap.
