toilet closet flange
  • toilet closet flange
    i'm renovating a 1/2 bath, and i had to pull up the subfloor due to improper installation, flex and a high joist.
    i would like to cut the pvc toilet pipe so i can get a snug fit around the waste pipe (3" i believe) with the new flooring.
    i suppose you should install a new closet flange after the finished floor is down.
    do you just install a coupler at the cut and then a 3" piece of pvc and then the flange?
    btw, i have access below in the basement, and the riser is fairly long.
    Re: toilet closet flange
    Depending on the depth of your riser out of the 90,it may be easier to coupling onto the horizontal and put a new 90 and riser.
    I love raised foundation homes.a lot of homes in this area are slab on grade.
