PEX-Cinch Clamps VS Rings
    Re: Pex: Cinch Clamps VS Rings
    This appears to be an Otiker clamp. I have a project I am working on where several of these have snaped at the water heater transitions. I am not certain as to the cause of the failures yet but I would probably not recommend them until I figure it out why they are failing.
    What did you find out ?
      Re: PEX-Cinch Clamps VS Rings
      I use copper crimp rings and Rehau pipe. I have never had a proper crimp leak....EVER. I been using the copper crimp rings since the pipe hit the market here in the early 90's. Some of my installs are approaching 20 years old and still working fine.
        i'm the only guy in my shop that uses the copper crimp rings, everyone else uses the cinch clamps or the newer zurn style
          Do you guys like the rings since you can keep tabs with the go no go gauge ? And adjust your own tool and not have to send it away ? What about keeping that ring in the right spot while getting the tool around it?
            I give the ring a slight squeeze with the slip joint pliers before before crimping to keep the ring in the right place. I use the crimp ring, never even done a cinch ring before.
            As for pex though I use Uponor Propex with the EP fittings. I like the system better than the crimp style.
            Will Rogers Plumbing
            Moore, Oklahoma
            405) 323-2852
            www.willrogersplumbing.com
              I've adjusted my crimp tools once in the last 15 years...its not like it should be an everyday thing. Copper crimp ring method.
                How do you go about installing pex do you crimp as you go or run every thing and come back and crimp every thing at the end?
                • #23
                  Crimp as you go. If you don't your asking for trouble.
                  Moore, Oklahoma
                  405) 323-2852
