Internal Wrench
  • Internal Wrench
    I am trying to use the RIDGID Internal Wrench (Model #342) to remove the drain from a bath tub but it won't work. Can anyone give me some tips?
    Re: Internal Wrench
    What's it doing?
      Re: Internal Wrench
      First, do you have the right size inserted into the tub drain? If so, what happens when you try to turn it? Does it slip?
      Some of those old tub shoes just wont budge. Better to use a cresent wrench on the handle for leverage. Be careful don't let it slip off and chip the tub finish. Been there...done that
      ~Bill
        Re: Internal Wrench
        The spud may be frozen in the waste shoe you may have to cut it out.You can use a sawzall and metal blade.Do you have acces to drain from underneath the tub
          Re: Internal Wrench
          Thats not a job for a beginner
            Re: Internal Wrench
            Hrrea3,
            Don't let him call you that
            Got any tool skills?
              Re: Internal Wrench
              Thanks, DrtyHands. The wrench slips. Yes, I have tools. I just want to replace the spud. I do have access, not easy, to the drain so i could replace the waste shoe if necessary. Any advice about cutting out the spud?
                Re: Internal Wrench
                I can as others tell you how to cut it out.Lets wait for a few tips,I dont use the wrench.
                  Re: Internal Wrench
                  My advice is DON'T do it!
                  You spent $50 on the proper tool to remove that spud now use it. I luv my 342
                  Are you sure you have the right insert for the tub drain inserted? It should just barely fit inside tub drain. If not, flip it over and try a different size.
                  I just hope it's not a enameled steel tub if you try to cut it out.
                    Re: Internal Wrench
                    It's a toss up between Sawzall,taking time with hacksaw blade with no frame,or replace waste shoe.Hope it can be done with the wrench,or other internal tool type option.
                    I know an electrical engineer that would differ with your point of view plumberscrack.Some people are very capable when well informed
                      Re: Internal Wrench
                      Thanks, Plumberscrack. Yes, I believe I am using the 342 correctly. The spud just won't budge.
                        Re: Internal Wrench
                        Dirty, I'm sure you've done it a number of times as I have. I only do it as a last resort. It takes time and above all patience. It been 10 years since I couldn't remove a spud with my wrench. Every now and then you get one that just wants to be a pecker. Try some penetrating oil overnight. The risk/reward is high when doing that. Please be careful.
                          Re: Internal Wrench
                          So, can you get a blade between the waste shoe and the underneath of the tub?
                            Re: Internal Wrench
                            The Ridgid internal wrench is a favorite specialty tool of mine. But, I don't know how well it works on a tub strainer, which is made of brass tubing.
                            the dog
                              Re: Internal Wrench
                              If you want to take a chance, you can use a chisel and hammer, and hitting closer to drain side of strainer piece, in the direction for it to unscrew. Several good blows with the hammer and it will turn out for you. Then you only need to replace that top strainer in to old shoe piece. I never chipped a tub doing it that way. and thats how I do them when they are tight. Freddy
