1.5" or 2" PVC preferred?
  • 1.5" or 2" PVC preferred?
    I am installing a kitchensink/dishwasher drain run and have to make a choice. The run is about 12' in length with one 90* turn (and now, it seems, a few more slight angles to get things aligned) and a good down running pitch in the cellar. The question is which would be better hydraulically, a 1.5" or 2" drain run? I ask because as I was doing my toilet drain a couple years ago I was told that a 3" pipe would work better hydraulically than a 4" and since that was a short run it made sense. Any thoughts on 1.5" vs 2" in this application?
    Thanks
    Re: 1.5" or 2" PVC preferred?
    is the run 12'' or 12'
    the santee in the wall should stub out 1.5'' with a trap. the bottom of the santee should then run 2'' into the main.
      Sorry, it's 12'. I have edited the post to read accurately. Thanks for the info.
        2" loop with a 1.5" foot vent,trap and trap arm.Don't forget your cleanouts
          What is the occupancy of this building. We are assuming residential....but he doesn't provide that information. In many cases disposal drains are sized 2" on commercial applications. If it is residential, which it probably is, I would agree with drty and Rick.
          the dog
            Just to provide more necessary info:
            Single family, residential, 1000sq/ft, 2BR bungalow occupied by 2 adults currently.
              Check the square ft again. It's length times width to figure it out. 100 sq ft is only 10'x10'.
                sometimes it feels like 10' x 10', especially when it's all torn up for a project.
                Just typing a bit too fast.
                1000 sq/ft., more or less.
