Threading s.s.
  • Threading s.s.
    a couple dumb questions from a millwright who should know
    do i need a special die for threading stainless pipe?
    can i get just the dies for my old ridgid tool holder?
    do you if i can get them in Winnipeg Manitoba Canada?
    The Canadian Millwright
    If you don't know, ASK!
    Re: Threading s.s.
    There are dies specifically for stainless steel.
      Re: Threading s.s.
      post the ridgid model # of your die head and i'll look up the part # for you
        Re: Threading s.s.
        As instructed above use dies for SS. But I would add:
        Use a lot of teflon tape, and a teflon based pipe dope.
        Measure and cut your pipe correctly because SS has little to no give. In other words, you can't tighten it up and then "schosh-it" another half turn to align it. When it's tight it's tight.
        In conclusion, I've worked with it alot and it's a pain in the ***.
        the dog
          Re: Threading s.s.
          A few more things use a cutter that only touched stainless steel same for the die heads.
            Re: Threading s.s.
            use ridgid high-speed pipe dies together with ridgid threading oil for stainless steel..
              Re: Threading s.s.
              Thanks anyway I Hired a Contractor.
