Problem with toilet
  • #46
    Re: Problem with toilet
    how many of you ware a respirator
    • #47
      I have one hanging in the cab of my van, I only use it when the customer mixes 2 different drain clearing chemicals toghether, it really doesn't help, but atleast I try to minimize my damage
      Robert
      • #48
        do you have to use purple primer where you are? Here only the HVAC inspectors make you use it, the plumbing guys allow clear
        West Trail Mechanical Ltd
        www.westtrailmechanical.ca
        • #49
          Pipe,
          Alot of our inspectors look for the purple.
          • #50
            The ASTM Standard requires it so both the IPC and UPC require it. However, there is some talk that things may change before the next Code cycle.
            • #51
              as far as i know plumbing needs to be purple
              HVAC does not
              • #52
                I just use blue glue by T. C. CHRISTY'S it is the first wet pvc glue, it has the glue and primer mixed togeather!!
                if i have dirty pvc or i want to make extra sure of a large joint i use purple primer then blue glue it set's extra fast and you can turn the water back on sooner then just clear glue!!
                JERRYMAC MASTERPLUMBER & MASTER DRAINMAN
                JERRYMAC
                E-MAILJERRYMAC777@GMAIL.COM
                FIRE SPRINKLER CONTRACTOR,
                SINCE JAN. 1989
                • #53
                  HVAC does not
                  I believe you are working under the IMC which lists the ASTM Standard for PVC in the tables of Chapter 12 so you probably need it for at least hydronic systems. As far as condensate waste I am not sure but because Chapter 3 has some generic language regarding installing equipment according to it's listing and approval I imagine an Inspector could require it.
                  • #54
                    Jerry,
                    If you read the label on Christy's Blue Glue you will see they tell you while they do not require it the Codes require purple primer be used with Blue Glue.
                    • #55
                      I would go with rick's plan and cut out from below and make permanent repairs,
                      NOT try to jerry rig!! something that you are just going to have problems with down the line,
                      i did plumbing service for over 30 years and on make shift jobs i always was called in to fix after homeowner or another plumber try'ed the cheap fix!!
                      useally after water damage to the house first!!
                      JERRYMAC
                      SINCE JAN. 1989
                      • #56
                        YES that must be something new since i got out of the feild!!
                        JERRYMAC
                        JERRYMAC
                        SINCE JAN. 1989
                        • #57
                          thanks i will check on this
                          i'm doing a job now that i'm using 6" sec 80 pvc so i Will check with the local inspector if he wants to see purple primer .
                          • #58
                            The job I was at last weekend was a job where my client installed 6,000' of 6" CPVC for a two pipe loop from the central plant to several detached buildings. They were not looking for glue joints so I was glad this question did not come up.
                            • #59
                              can we stop with the extra bold
                              kinda painfull for the eyes
                              • #60
                                The blue glue is my preference but not legal in the IPC as it is too close to purple in color . Not allowed in Oklahoma. I use a med bodied oatey clear for pvc
