PVC cutter tool failure
  • PVC cutter tool failure
    sorry for this basic ?? but my pvc cutter keeps on failing
    they seem to be very cheaply made and I cannot find a pair that works much longer than a month
    what brand of pvc/cpvc cutter do you use and how long should i expect them to last?
    thanks
    Re: PVC cutter tool failure
    If you buy em from a "box store" use it once and get another. I brake em all the time
      I like the rothenberger with the pointed blades. I also have the new ridgid cutters they do the job but you have to open them really wide to cut one inch. My biggest problem is losing them.
        Try a ridgid cutter like you would use for copper - but get the plastic cutting wheel...
        That is all I use for plastic up to 2" - from 2" to 4" I use a large Reed cutter with a plastic wheel...
          What size pvc are you trying to cut? I have an old ridgid cutter for up to 2" that says "made in Japan" that's similar to the ones you see at HD with the ratcheting handle. I needed a new blade and the cheapest I found was 55.00 so I bought the one at HD for 30 and transferred the blade onto my ridgid and it works great.
            i run a knife sharpener on my blade when it gets dull ,works good
              Man I know thats right...lol.. I have 3 in my trailer and I cant ever find just one....rotflmao
