Silicone or plumber's putty?
    Re: Silicone or plumber's putty?
    Originally posted by BAPlumber View Post
    I've used putty (as an extra measure) on the nylon bevel washers on plastic p-traps for the last 7-10 years. I've recently been told this will cause the slip nuts and tubing to crack, and was a big no-no. never seen a problem or had a call back on this. Any opinions on this?
    most pipe dopes are not approved for plastic. a teflon based dope usually is approved for plastic. the beveled 1.5'' and 1.25'' x 1.5'' slip joint washers don't require any kind of dope or sealant. i like them much better thn the rubber s.j. washers and they last a lot longer too.
      Yeah, I realize the bevel washers don't require an additional sealant, but like with threaded connections, a lot of plumbers use both tape and dope, which isn't required. I guess my question is if anyone has seen a problem with plumber's putty reacting with the plastic?
      Brent
