Pressure or volume problem.
  • Pressure or volume problem.
    Awhile back i had some plumbing work done and when the water was turned back on the pressure was not the same. When you first turn the water on at any faucet it comes out normally for about 5-8 seconds then its only about maybe 1/4 of normal. Leave the faucet off for 10-15 seconds and then turn it on and it's normal again for a few seconds. The maintenance guy comes over and takes a look around for leaks and then replies that the pipes must be clogged. I tried to explain that it was fine until the water was shut off then turned back on, but he thinks it's clogged pipes. Any help/advice would be appreciated.
    Re: Pressure or volume problem.
    My only thought is if they turned the valve all the way on.
      Sounds like volume if the pressure is there when you first turn on the tap. Did they turn the main valve on all the way after they shut it off?
        What type of work did you have done and what kind of pipe is in your house?
          it's a volume issue that keeps the pressure low.
          i would verify that the main shut off valve is open the whole way and not broken. also if there is a pressure regulator, make sure the filter screen is not plugged up.
          this is on a city water supply correct?
          it does affect both hot and cold?
          how about your outside irrigation system?
          i've even seen where the water meter has failed and creates this issue.
            The water was shut off to replace the water heater. The pipe is plastic for both the hot and cold. The problem exists for both hot and cold water. No irrigation system is installed. Yes it's city water, i suspect it's the main shut off valve is broken or damaged(looks very old) because it seems to take a lot of effort to turn it off and on, more than should be required.
              Possible main valve problem. Maybe the gate dropped in the valve.
