Pex ???
  • Pex ???
    Just started with an AC company a few months ago...company also does plumbing...were In Florida BTW....any way when Slow I play plumers helper....ran accross PEX in the process....even plumers say they never used it till they got to this shop...Seems like neat stuff...simple...even an ac guy can do it but got some ??? about it. Tried doing a search on this site and got nothing for PEX...even when I seen it in a few post....
    Is pex a fairly new thing? Is it commonly used in the pluming trades in other states?
    We use 20ft sections..even for a repipe...but on a web site seen it in rolls..how do u all use it rolls or sections? any advantage /disadvantage of rolls vs sections? Thinking less joints.
    We only use the clear/white stuff...1/2" and 3/4" for residential work...not super sure....since only help a little....but how large do they make pex?..ie up to 4" or just small stuff.
    On one web site about pex I noticed some came with a matalic coating....said advantage of copper with PEX or something like that....anyone used the encased pex? why? what is the advantage of it?
    About it...but please add anything u think might help a lost ac guy understand pex...thanks all.
    Re: Pex ???
    Originally posted by Evil Gopher View Post
    Is pex a fairly new thing? Is it commonly used in the pluming trades in other states?over 30 years in Europe, not sure about the states
    We use 20ft sections..even for a repipe...but on a web site seen it in rolls..how do u all use it rolls or sections? any advantage /disadvantage of rolls vs sections? Thinking less joints. That's right, can't have any joints in a slab. Roll the line out to a manifold in the wall and branch out from there. Sunlight is pex's big problem coupled with improper installation. Remember you need strapping at least every 32". It will bend but only so much. Big problems are the bands being installed crooked causing leaks. Pex does expand and contract so expansion loops are used.
    We only use the clear/white stuff...1/2" and 3/4" for residential work...not super sure....since only help a little....but how large do they make pex?..ie up to 4" or just small stuff. 1" is the biggest I've seen but I'm sure you can get bigger
    On one web site about pex I noticed some came with a matalic coating....said advantage of copper with PEX or something like that....anyone used the encased pex? why? what is the advantage of it? Oxygen can't get into the water. Mostly used in hydronics (radiators)
    Maybe a search of manufactors will help. Zurn, rehau, upnor, wirsbo.
    Hope this helps.
      Re: Pex ???
      http://www.ridgidforum.com/forum/showthread.php?t=13509
      http://www.ridgidforum.com/forum/showthread.php?t=11542
      http://www.ridgidforum.com/forum/showthread.php?t=9820
      http://www.ridgidforum.com/forum/showthread.php?t=9773
      http://www.ridgidforum.com/forum/showthread.php?t=8678
      http://www.ridgidforum.com/forum/showthread.php?t=8217
      http://www.ridgidforum.com/forum/showthread.php?t=8268
      You will never expand your mind, if you do not challenge your beliefs.
      By the reading of this post, you acknowledge and agree that the poster shall not be responsible or liable, directly or indirectly, for any damage or loss caused or alleged to be caused by or in connection with use of or reliance on any content contained herein.
        Re: Pex ???
        Hope this helps.
        Ben, I thought Upnor made Wirsbo
        Robert
          Re: Pex ???
          I don't know, maybe they do. I just listed those as keywords to a search engine.
            Re: Pex ???
            Thanks all...that will keep me reading for a few days..
              Re: Pex ???
              upnor makes worbo, aquapex, he-pex, my wife is a product rep
              how is it that so many answers are in the instructions
