The Green Monster !!
  • The Green Monster !!
    Happens some times, Cleaned and fluxed some 2 " copper .Get a call ,Must leave for appt. right now! Come back 3 hrs later, green flux ! Usually ,I clean and re-flux,didn't this time.
    Solder flowed fine. Whats Your opinion,please. Thanks Tool
    Re: The Green Monster !!
    I usually take it apart sand and flux again but I have also soldered a week later without a leak but never on a 2" fitting.
      What kind of flux do you use?
        Everflux will do it, but not in 3 hrs
        I will take it apart and re-solder it, but sounds like if the solder flowed fine, you have nothing to worry about.
        Robert
          Yep,it happens,sometimes we'll run assembly of pipe and fittings for hours then go back towards the end of the day and solder up.All the fluxes that I have use have been fine,Yes Evereflux too
          After a prolonged period of time the outside of the fluxed but unsoldered fitting will start to turn green,but if you have the opportunity to pull the fitting apart you will notice that inside that has not been exposed to air is fine after a few hours.
          If the fitting has been soldered and has a green gap or leaks,the only way to guaranty a lasting fitting is to pull it.
            i use Nokorode pre tinting flux and you can come back 1 week later and still is good
              Look through Dad's celler, and find a tin of OLD Nokorode.
