heating system valve leak, please help!
  • heating system valve leak, please help!
    I have two valves leak (maybe too old). One is in the heating system. here is the photos: http://flickr.com/photos/lmei007/?saved=1 All of them are on the basement ceiling.
    Questions for you guys:
    Do I need to replace the whole valve? Can I just replace the parts to avoid cut and soldering? (The 'good valve' shows the parts replacement?)
    my heating system is oil water system. Do I need to drain out all the water to do the replacement?
    how much it will cost roughly for a professional to do it?
    thanks
    Re: heating system valve leak, please help!
    thanks
    I tightened the packing nuts according to one experter from other forum. It works. thank you.
      wow. i can't be live that you still have the asbestos pipe intolation on the pipes.
      it will be fine but expect that if a plumber does come to your home they might charge you extra because of that. though i thought(and might be very wrong) that if you have bought a house within the last 4 years it has to be both lead and asbestos free
      9/11/01, never forget.
        the out side white part looks like the type that would be on asbestos but the in side dies not look like it is . asbestos looks like a honeycomb
