priming the pipe
  • priming the pipe
    i have had alot of people over the years tell me that you should run the a sink for a minute or two before you flush soild waste so it will slide though the pipes easier with less chance of a back up??? is there any truth to this? or is this just a myth from the days we frist went to low flow?
    just for the recorded i have never had a problem.
    9/11/01, never forget.
    Re: priming the pipe
    I actually had someone ask me one time if flushing a small rag down a toilet, will that help clean the pipes?? WTF
    Never heard of your senario....sounds like one of those myths
      on a kitchen sink with a disposal, it's very good practice to run the water for 10 seconds prior to turning on the disposal. also keep the water on for another 10 seconds after grinding. finally feed the disposal as if you were chewing and eating the food. don't choke your disposal. the water needs to help carry the waste down the pipe. all food with no water is a heimlic/ stoppage waiting to happen.
        umm rick, how do i put this nicely, i ummm ment from the south side of the body, not a disposal, but you do bring up good point about them.
          ah, i see. the answer i have for you is to buy joeys bidet seat and you won't need to worry about paper.
          then i won't need to worry about joeys new gift collecting dust
          there are 2 isolated condo buildings that i work at that this is true.
          the powder room low flow 1.6gpf toilets are isolated from the rest of the dwv system by 40' and 80' of piping. so because of this i have them either pre-flush, double flush or keep the lav sink running.
          there is no real way to fix these 2 isolated issues. the original design is the problem. of course a 3.5 gallon toilet would fix it.
          so unless you have real bad plumbing or live in a florida palace, you'll be fine.
          buy joeys gift and i'll be better
            From a engineering standpoint this could work in the right situation. However you will need a rag of decent size proper texture.
            Throw it in the toilet and flush quickly before it starts to absorb too much water. Flush once and let it sit there a while. Flush a second time to confirm that sanitary line is indeed stopped up. Then call a plumber (licensed) and tell him not to retrieve the stoppage but push it downstream past the first cleanout. Then he just keeps this up (adding additional cleanouts as necessary for push locations) until he pushes it into the city main.
            Many hours later and you checking account ~$1,000.00 or so lighter, you have cleaner sanitary main.
            Regards,
              Regards,
              Brilliant, bloody brilliant. a direct page from the silvan book of screwing the customer
              steve
                steve
                lmao i am sure he was just joking and being sarcastic.
                  Oh crap,
                  As OSC said, I was just being a smart ***! I did not mean for anyone to take that literally.
                  Regards,
                    Rick, This made me think of "The Royal Flush" where a 5 gallon pail most of the way full of water comes in handy. Before the building closes each evening flush the remote toilets and then pour a pail of additional water into each of them. That way each gets a nice big 6 gallon real flush.
                      Biscuit, i did take it as a joke. i guess my humorous retort wasn't that funny after all. i'll work on my timing and delivery
                      steve
                        bah hahahahahaha
                        funniest thing ever!!!!
                        yeah yeah yeah i know i know............. go stand in the corner i know....
                          kohler just sent them 12 new colored 1 pc. toilets to replace the 3 year old ones they already have. it's not going to fix the problem, as it's 80' to the main sewer common plumbing.
                          the bucket trick is good, but tell that to people in their 70's-80's
                            the bucket trick is good, but tell that to people in their 70's-80's rick.
                            In that case maybe just suggest they flush, let it fill up and flush again to help wash it to the main. Everday I love my old American Standard vintage toilet with a good hefty 5 gallon flush more and more. It does know what "The Royal Flush" is about. Best part is that it never needs the bucket flush.
                              I have had at least two jobs where the toilets had worked fine for years and years. They then remodeled and put 1.6 gpf toilets in and began to plug lines often. In one case, I was able to jet up from the septic tank and remove a few pounds of cast iron sand and they've not called back. In another, the low flow feature of the toilet was a plastic bucket/tank/insert inside of the porcelain tank.... a 1" slot cut out of either side of it allowed water to fill the space between the plastic liner and the porcelain and added a gallon or so to a flush and has helped dramatically.... Low flo toilets make me more money than garbage disposals.
