galvanized to brass - dielectric union needed?
    Re: galvanized to brass - dielectric union needed?
    Not to digress however, I am hoping to confirm a couple things. First, I am OK to go from galvanized city line to brass valve to copper in the house, without any dielectric union. Second, my static pressure, is around 45psi, confirming, without angering, that I do not need a PRV. On a seperate note in my trade, Fire dept., there are many threads and forums that we use exclusively for education and it seems to work really well. Just a thought.
    Thanks to all.
    Sean
      Your good to go.The boys have looked it over and your on your way.
      There is only one problem........................................... ....Your still a fireman
      Sorry,I couldn't resist.
      I have two captains,a handfull of firemen and a chief for friends.My girlfriends brother is an engineer($110,000 a year to polish the chrome on a truck is pretty good).
      Welcome to the forum Sean.Call back if you need anything.
        Thanks to all.
        Sean
        The brass will act as a dielectric. The standard in the industry is 6" hence Adam's suggestion of adding a brass nipple. Your pressure is well below the level where you would need a PRV.
          Thanks to all.
          Sean
          Sean, at 45, you don't need a PRV.
          A 3" brass nipple and a ball valve will give you your 6" of protection against electrolosis.
          As for the code requirements, I have purchased the 2006 UPC and have been peeking now and then. You do not have to use Hammer Arrestors, you can install a 2' piece of copper in the wall running verticly with a tee and a cap to make an air chamber. All mechanical hammer arrestors have to have access panels so they are readily accessable, as an "Air Chamber" can be buried in the wall, it is not considered a mechanical device.
          Robert
            Robert,
            The Hammer arrestor was thread drift.He knows
              Thanks for all the help!! This seems like a much better idea than asking the self proclaimed experts at the Firehouse. Turns out we have some free time, after all how much time can you really spend polishing the rig!! Thanks again and Happy Holidays to all!! I'm sure that I'll be back with more questions as my plumbing adventure progresses.
              Sean
                Sean
                • #23
                  In my area, the best way to go is to use a stainless steel nipple between copper and galvanised. Galvanised to brass is a guaranteed future leaker. Or if you go to wrench them apart, the galvanised breaks.
                  • #24
                    Robert,
                    Sorry, I get carried away with myself.
                    • #25
                      Why does the length matter?
                      • #26
                        Ben,the O/P's question was addressed before the drift.
                        • #27
                          It separates the molecular activity.I look at like keeping two magnets separate.Maybe there is a better analogy.
