I'm going to daisy chain TWO on demand heaters!!!!!!!!!!!!
  • #46
    Re: I'm going to daisy chain TWO on demand heaters!!!!!!!!!!!!
    Originally posted by plumberscrack View Post
    A few years ago I installed a Rinnai as a boiler for an addition. Flipping through their website now I don't see the piping diagram I used. In fact, I dont see any space heating diagrams. I wonder if they don't recommend that anymore.
    I just took the class recently from Rinnai. If anyone going to DC wants a copy of their installation literature, PM me and I'll bring it up with me.
    • #47
      I have a friend who is an electrical contractor and recently switched to a small electric tankless. He and his family have had to endure some colder than normal showers but he says he is saving $100 per month on his electric.
      • #48
        also i see a small electric water heater, is that for your circ. line? This should be 6 gal water heater. It's installed so there are no "cold spots" of water. Kinda evens things out a bit. Our instructor said you could use a 2 gal WH but the hot/cold lines aren't the right size so 6 gal is the minimum.
        i was under the impression that pex and cpvc needed to be 18'' from the heaters? That's what the code is here but they did do a pretty good job of that cpvc. I disagree with a couple things but it looks good at first glance.
        Ben
        • #49
          Look at the two different installers.
          The owner of the company who did the show pipe under units.
          Then turns it back over to the crooked pipe crew.AAAARRRON
          Take a good look at your future,PLUMBERS
          • #50
            arron, interesting that they ran medium pressure gas, but didn't have to vent the gas regulators. also i see a small electric water heater, is that for your circ. line? are all these heaters connected to a common 3/4'' or 1'' cpvc line?
            is this for both domestic heating and space heating? or do they use a lot of hot water?
            Rick, I see regulators and they do make regulators that don't need to be vented.
            Yes, the electric water heater is for the circulation line.
            Robert
            • #51
              Semi-humorous thought...If you were taking cold showers, you'd use it less too.
              What I've learned of the electric tankless's is the only difference in operating cost is the lack of standby heat loss...doing the math on standby heat loss for a 50 gal tank comes to maybe a few bucks a month.
              Most electric heaters run in the high 90% efficiency range, tank or tankless, so I'd like to know how he's saving that much?
              For giggles, I typed a search for "surface area of a water tank" and found this site...though I'd wager it's outdated, I'd also wager it's not too far off:
              Hot Water Heater Tank, Heat Loss Calculation
              • #52
                Originally posted by Aaron91 View Post
                The company I work for did this house. I don't remember off hand the model these heaters were, sorry.
                I have a few questions for the pros. It is hard to tell, but it looks like they ran 3/4in cpvc to feed all the units. They then transitioned into 1in cpvc, which is the main hot water line and cold water line inlet. Wouldn't this cause a restriction? It seems like they need high volume for this structure. Wouldn't it have been better to run the 1" line the span of the units? They would then "T" into it and add a reducer bushing before entering each tankless unit. Basically, they would run the 1" line the entire way.
                Also, I'm assuming these things are not staged because I do not see any solenoids etc. Is this correct? Would they all be set to come on at the same time?
                • #53
                  The west coast crew must still be out drinking.
                  • #54
                    the gas regulators have a pop it in the vent and this does not allow the gas to come out if the regulator blows .
                    if i was to run the gas line i would have ran one line to the top of the heaters at a higher pressure then put a regulator on that line and run a header with all the branches to the other heaters . i would have ran hard pipe and not yellow pipe ,it looks better .but looking at the other pipes looks don't mater here
                    • #55
                      whats the point of that install?im looking at atleast $5000 just for the tanks? and there is obviously enough room for a tank whats the benefit of that system? i dont have alot of knowledge with the tankless?
                      Mike
                      www.plumbinginclarkcounty.com
                      • #56
                        There is about a million BTUs hanging on the wall which represents a lot of fuel. Instead of having a couple of large tanks heating water 24/7 you have tankless heaters which have controllers which fire the heaters on demand and only enough of the heaters to supply the needed demand.
                        • #57
                          Shouldnt the vents off those regulators be piped outside?
                          • #58
                            I downloaded Aaron's photo and squared it up. Things don't look so out of plumb now for the most part. Also, I'm thinking that each of these tankless heaters is dedicated to a specific Bath, Kitchen, or Power room, and their output is not combined to feed to whole house (I believe Aaron said this was a house).
                            • #59
                              Sorry guys, there was a whole page worth of posts that I missed.
                              • #60
                                depends on the code we can just have the pop it in for small regulators
