Connecting basement plumbing to cast iron waste stack
  • Connecting basement plumbing to cast iron waste stack
    I'm putting in a half bath and a washing machine in our basement and I'd like to like to connect it to the main stack and drain, which is all 4-inch cast iron. The sweep where the stack meets the sewer line has no clean out and appears to have some corrosion, so I'd like to replace it. I was thinking that I would cut out the sweep about 2 feet up the stack and one foot along the sewer line with a snap cutter and replace it with PVC, making the connection to the cast iron with banded couplings both above and below ground. Above ground the PVC would include a clean out and a connector for the washer drain pipe. Below ground the sweep would include a reducing Y fitting to accept the 3-inch toilet drain pipe. I've figured out the venting and I'm planning to put in a few riser clamps to ensure the cast iron above the PVC is adequately supported.
    My questions would be a) Does this seem like a sound plan?, b) Are there any issues with banded couplings under ground?, and c) Is there anything I'm missing?
    Re: Connecting basement plumbing to cast iron waste stack
    sounds like you got it figured out. make sure you use a shielded coupling that is approved for a transition between cast and pvc/ plastic.
    i personally would shy away from the snap cutter on older pipe. too much of a risk of crushing/ cracking the old cast. a 4.5'' grinder and cut off or diamond blade is safer
    post pictures as you progress and we can watch this job live.
